Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lets see your dyno sheet!
  #23 (permalink)
Old 10-07-2012, 12:19 PM
Madmax305's Avatar
Madmax305 Madmax305 is offline
Forgot to mention: 2003 Mach-1, built more for roadracing...
LIVERNOIS 5.0 STROKER
PORT/POLISH-FRPP HEADS/ RACING CAMS
KB 2.8 15LBS 570RWHP 550RWTQ (SAE) STREET TUNE PUMP GAS
LDC COOLING MOD, DAVIS WP, 8-RIB BELT
TKO 600 .82OD
3.55 GEARS
EATON POSI/31 SPLINE AXLES
COBRA TANK/PUMPS, SCT-2800 MAF, BAP
60LB INJ, FORE FUEL RAILS, -8AN FUEL LINE
BASSANI HEADERS/X-PIPE
CANTON 8QT PAN
MAXIMUM MOTORSPORT TUBULAR K-MEMBER/PANHARD BAR/TORQUE ARM
ALUMINUM D.S./FLYWHEEL
BILSTEIN SPORT VALVE COILOVERS ON ALL CORNERS
3400 LBS
4-PISTON BREMBO CALIPERS/ROTORS
18X9/18X10 CHROME BULLITS/NITTO DR'S
2001 COBRA FRONT COVER
RET Tune
