lets talk brake trouble
History, S-10 conversion, 12 years ago. Now i am putting it back to use.
Now the trouble. soft peddle, no fluid to rear, leaking rear cylinders, and so on. What I have done. Replaced all lines (front and rear) calipers and rear cylinders pads and shoes master cylinder and valve used power boost (because I had a soft peddle after changing calipers and rear cylinders) now i have a hard peddle The new trouble is now, no good pressure at brakes. checked the boost by removing vacuum, slight press on peddle and feel small movement on start-up. Any thoughts? |
Now wait a Min.....You said ...(no fluid to rear, leaking rear cylinders)..
How do you know they are leaking if you said No fluid to rear... Did you re-bleed everything (right) ???? |
sorry, no fluid when i started fixing. The one rear brake was all wet.
From CPP's "Brake Troubleshooting Guide":
Rock Hard Pedal • Insufficient Vacuum = Check vacuum pressure • Blocked Vacuum Check Valve = Test Power Brake Booster • Bad power booster = Test Power Brake Booster • Frozen Wheel Cylinder = Replace caliper • Binding Pedal linkage = Inspect pedal assembly |
| lets talk | newbie2011 | Introduce Yourself | 1 | 12-06-2010 05:38 PM |
| Lets talk | murray fancy | Introduce Yourself | 3 | 12-03-2010 05:32 PM |
| Lets talk about Patriot | BMM | Hotrodders' Lounge | 4 | 09-06-2008 03:23 PM |
| lets talk crap | akm | Hotrodders' Lounge | 46 | 03-21-2004 02:39 PM |
| Lets talk about polishing. | 4 Jaw Chuck | Body - Exterior | 4 | 12-17-2002 12:53 PM |
