Lets talk engine advance! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2004, 11:31 AM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Ok, first of all forgive me for a noob question, we all gotta learn sometime
Now,
I understand that at higher RPM the sparkplug has to fire a bit before TDC........I dont know why so that's why I'm here. I dont understand how this is achieved? What caues the spark plug to fire a bit before TDC? Is it something in the distributor? Bascially I need to know EVERYTHING about engine advance.....thanks
Mike
Old 10-10-2004, 05:08 PM
lluciano77's Avatar
You need advance because gasoline burns slow. You need the flamefront to achieve it's strongest point just as the piston is passing TDC. In order to time this correctly, the spark has to happen before TDC.
Old 10-11-2004, 07:41 AM
Old School Nut's Avatar
machinest & A&P Mechanic
Last journal entry: distributer housing...
you are correct to, their is a thing in the distributer (weights and springs) that change your advance, thier is also a vacuum can on some distributers that is "fed" from the intake.
Old 10-11-2004, 10:06 AM
malc's Avatar
Living At The Speed Of Life
Try this site http://auto.howstuffworks.com/ignition-system.htm don´t forget to click, next page.
Here´s another timing article http://www.chevyhiperformance.com/ho...673/index.html
