let's talk fuel filters - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2005, 10:41 PM
Too Damn Slow
What do you guys prefer? Paper element or screen? Canister style or log type? Any flow better than others? Any suggestions on wether carbs are more sensative to particle contamination than fuel injection? Does it pay to filter down to 10 microns if the carb won't care until say 100 microns? I know everyone has their favorite brands for fuel systems, but what are the generalities when selecting parts? I am considering adding a fuel cell and redoing a section of my fuel system including the filter.
Old 04-03-2005, 01:20 PM
Docs91RS's Avatar
Well I use a canister type with a replaceable paper element which is rated at 40 microns. As far as microns go I've seen them from 100 on down to 8 microns. The significance other than extremely clean fuel and bragging rights from a markets standpoint I ve personally seen no difference. Most of the people I see run between 40 and 80 micron filters with out any problems. The best advice I can give you is make sure the filter is rated to flow the same or more Gallons Per Hour (GPH) than your pump. In other words if your running a 140 GPH pump make sure the filter is rated to flow 140 GPH or more otherwise it will become a restriction. I think the shape is a matter of perference but if space is restricted this may dictate the shape. IMO the Log filters make for a cleaner looking install though, which is why Im switchin to one this year.
Doc
Old 04-03-2005, 04:12 PM
Tazz
What Doc says makes sense....
I always buy expensive filters...I think you get what you pay for...so buy the good ones.
Tazz
Rat Rods Rule!
Old 04-03-2005, 06:49 PM
Too Damn Slow
Right now I am using a new factory tank and a Russell filter with a Holley Blue pump. I was having fuel pickup issues, but I fixed them today. The puckup tube was a little too long and was sucking tight to the bottom of the tank. I also have all new braided stainless hose. I am still concerned with the -6 line coming out of the tank to the filter. The rest is -8.
Old 04-03-2005, 07:02 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
I use a clear Wix filter so I can see when I have any trash build up. But I have a mechanical pump. and stock tank and lines 3/8''........Ed
Old 04-04-2005, 06:12 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
all wix filters for me, with a KN handling the air being the only exception.
Old 04-05-2005, 02:10 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
filters
There illegal on a race track.
Use an aluminum bodied in line filter with replaceable paper cartiridges.
Old 04-07-2005, 06:13 AM
cuda66273's Avatar
Your backwards, you need to run -08 from the tank and 06 up, using a small supply line to a big feed line slows the reaction time of the fuel demand and can lean you out.
Here's a nice set-up for a mechanical supply system to about 400 HP, the billet filter flows at about 120 GPH with a lifetime, cleanable, SS, 40 Micron Screen. They run about $50 but it's the last filter you'll probably ever buy.
100 Microns are chunks, 8 microns are almost undetectable by the human eye and would only be used in a clean room at Walker Siltronics. Be very careful of those little, glass, screen type, inline filters they flow very little, they're for a stock Honda....not your American Muscle V-8
Old 12-10-2005, 11:36 AM
flaming79's Avatar
Run it if you build it !!
Last journal entry: Almost ready to go cruzn
WHAT WOULD BE A GOOD SET UP FOR A 400-500 HORSE MOTOR WITH A MECH. PUMP. I JUST GOT A RACE DEMON TRING TO FIGURE OUT A NICE SET UP WITH A FUEL LOG, PRESSURE REGULATOR, GUAGE, EXT. SHOULD I RUN NEW LINES FROM THE TANK TO THE PUMP? WILL THE STOCK LINES BE TO RESTRICTIVE?
THANKS FOR THE FEEDBACK..
flaming79
anyone have any tricks for vaporising fuel for more mileage? sc2dave Engine 185 11-08-2007 02:07 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
fuel cell installation 19nova72 Engine 5 11-19-2004 04:36 PM
glass fuel filters? Brian Morency Engine 17 11-01-2004 04:36 AM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 12:36 AM
