I've got a problem with the 36 grit for filler. I've been doing bodywork for 22 years and cant remember the last time I even felt a piece of 36. If you have to start out with that, you need to learn how to put your filler on a little better.
I generally use 36 to cut through the paint prior to filler and then sand the filler with 80 grit. If I'm using 3M fillers, I hit the filler with 36 grit to remove the crap that gums up 80 grit. Evercoat doesn't seem to require it so I start with 80 grit on Evercoat.
I don't sand sealer or basecoat unless I have a run or a big "booger". If it's basecoat, then I reshoot the color. The paint will stick like glue without it.. and you can mess up the color of the basecoats by sanding... especially metallics.
Here is a tip: Muguiars papers cost more... but you don't get that one large rock on each sheet that cuts a nice scratch in the paint. |
I "knock 'er down" Filler with 80, then quickly change to 180. I don't sand Epoxy with anything rougher than 180.
I see someone brought up Sandpaper brands, and wondered if everyone could also include their preferred Brand of Sandpaper. Hands down I use PSA rolls the most, I've tried 3M (the worst IMO), and Norton, but my favorite brand is Carborundum- |
Filler I start with 80's and finish with 240's
Primer....if I'm only priming the once I'll use 600's wet or if I'm priming twice I'll go 400's dry,re-prime and then 600's wet I'm not entirely sure if UK grits are the same as USA
OK, good replies.
What do you consider a minimum grit before (good) filler? I'd think 180 is border line but many may argue that. You? What is the roughest you'd use before basecoat to avoid sand scratches? 400? 600?? Will basecoat even stick to much finer? How critical do you feel between the difference of chemical bond of basecoat over primer (wet on wet, or within the reshoot window) versus mechanical (primer sanded after setting up) for adhesion? These are some things I've got a bit of a handle on, but never really see discussed in detail. I'm sure many of us can learn a few pointers here, and maybe even avoid leaving some paint on the road at highway speeds!
On my candy job, i was thinking of sanding the clear and giving it 3 more coats of clear for more depth. What grit is recommended? 800? Also was thinking i may need a scotch pad, especially for the tight areas, would the red color be used and would it be helpful? the clear is really tough stuff, so not sure if the scoth bad would even help
From rough to fine the only grits I keep stocked are used in the same order although most projects start at 80 grit but there are times that call for 36 on a "killer" or 8 inch "mudder da"
http://www.a2zautoforums.com/showpos...84&postcount=6 IE. 36 tough stuff 80 bondo 180 finish putty 320 machine prep 400 blocking for paint (red scuff pad) (during a blend grey ultrafine scuff foam pad) 1000 after paint (grey scuuf pad) 2000 after 1000 Last edited by milo; 01-06-2011 at 02:53 AM. |
sanpaper brands
Tucson Jay
Can you say a little more about brands of sandpaper? The reason I ask is I just finished up a black bc/cc job. Started color sanding with 800-1200-1500-2000 and finished up with 2500. When I started buffing I noticed some scratches that won't buff out and I don't know where they came from. I use a 'name' brand wet/dry sandpaper my local jobber carries. Could the sandpaper have defects that cause these scratches? Are some brands worse than others? Ron |
you probably picked up some grit when you were wet sanding.....especially if you use a bucket
I figure it's just the coarse paper scratches that I missed. It's really hard to get them all. |
| Sandpaper & NAPA | Irelands child | Body - Exterior | 35 | 08-11-2007 11:44 AM |
| sandpaper grit | ucmung | Body - Exterior | 5 | 12-04-2006 06:10 AM |
| How much sandpaper? | hgufrin | Body - Exterior | 2 | 09-21-2006 06:58 AM |
| sandpaper | bluenovadog | Body - Exterior | 5 | 03-22-2006 03:32 PM |
| sandpaper... | 38 special | Body - Exterior | 14 | 10-11-2005 04:30 PM |
