leveling a engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2007, 06:56 PM
leveling a engine
Im new to doing this kinda stuff but i want to learn so here i go. Most of the people here wouldnt consider this a hot rod(VW scirocco), what i want to do is a motor swap, but i have to weld in new motor mounts. My problem is i have pretty much everything lined up but want to be as exact as i can but i dont know how to level the motor? Do i just put a level on it and call it good?
Old 10-29-2007, 07:26 PM
Marcel
Last journal entry: Choo-choo town
leveling the engine
I'd level the top of the carb (if it has 1) front 2 rear and side 2 side. Most engines aren't level,but the induction system is.
Old 10-30-2007, 12:57 PM
gdubstub's Avatar
Old Crusty Streetrodder
The carb flange is usually level, but be sure to take into consideration the stance of the car. If you plan to modify the car's rake, set your motor with the full weight of the engine/trans on the frame and the car at the desired rake FIRST.
Also, take into consideration the driveline geometry before setting the engine. Inland Empire Driveline has some good tips for this.
I don't want to break your heart, but there's more to engine swapping than welding in new mounts.
George
Old 10-30-2007, 04:34 PM
seriousracer's Avatar
be a man dodge tree bark!
what motor due you want to put in there?
need more info...
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 01:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Engine....whats it worth? chevyusa1 Engine 6 06-11-2007 07:43 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 08:50 AM
