Lexan Windshield - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2003, 04:06 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post Lexan Windshield
Not much response in General so.....
Have any of you worked with lexan windshields? If so, what thickness are you using and are you using a center support.
Thanks,
Chris
Old 01-14-2003, 07:45 AM
deuce_454's Avatar
Post
for racing here we are not allowed to run less than 6mm. which is about 1/4 inch, i think you can go as thin as 3/16 but then you should propably run two vertican supports (nascar style) to prevent it wobling, but a windscreen with high curvature will be less prone to wobble than a flatter one. and when it gets scratched (which happens fast) you can buff it with a paint buffing and polishing compound, just dont use the coarse stuff.
Old 01-14-2003, 08:08 AM
TurboS10's Avatar
Wiki Edits: 2
Post
Thanks, 1/4 is what I was thinking.
Chris
Old 01-14-2003, 05:10 PM
Mrfixmaster's Avatar
Last journal entry: Red, my second T--Bucket
Post
Had a piece of 3/8 for a temporary windshield on my T-bucket for last summer.(Got it for free, so even if it was too thick, it was great!) Worked fine, but scratching & cleaning are a problem. Found out that Pledge furniture polish sprayed on and wiped off with a new soft cloth was the best. If you're thniking about running it on the street, be forewarned it ain't legal most places.
Not that being legal has ever stopped most of us!!
Old 01-15-2003, 07:11 AM
New Member
Post
What, you mean my blue dots, high DB glass packs, no front license plate, etc. aren't legal? Well I never . . .!
