lift and duration? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2003, 10:01 PM
akm akm is offline
lift and duration?
can someone explain this to me?
stock--
mild--
high--
Old 08-21-2003, 10:34 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I'm not sure what you are asking. If you mean what are the numbers then there are a few variances. If this is what you want I will be glade to try to explian them all.
Old 08-21-2003, 10:48 PM
akm akm is offline
when someone says lift and duration, i don't know what that meens. but i think if you have more lift and duration, you get better proformace.
i would like someone to explain how it works and how i can tell the differance between a stock, mild, or high proformance cam.
or what ever else it has to do with.
thanks
Old 08-22-2003, 08:49 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Please go to the Knowledge Base, as it has all the info that you want. Or go to CompCams site they have it all on one site.
http://www.compcams.com/information/NewProducts/2003/
Luv the smell of NITRO in the morning.
Old 08-22-2003, 06:46 PM
Vetter
Well, in a high-performance car you want high lift and low duration. The reason for the low duration is because in the strokes of an engine, there is a quick overlap in which the intake valve is open as well as the exaust valve. And the lower the duration, the less time that this is (or the total rid of time) where they are both open, resulting in the less loss of air, and high compression. Of course, this is another one of those things where you have to watch with higher compressions, as there as also disadvantageous results if not well thought out.
Good luck!
78SilverShark
Old 08-22-2003, 11:19 PM
akm akm is offline
thanks alot
anyone else that can show some numbers and tell me the differents?
thanks
Old 08-23-2003, 07:41 AM
1BAD80's Avatar
Wiki Edits: 2
How about going to this site and get the #s yourself and the information that your asking for. One must help oneself.
http://www.compcams.com/information/tutorials/
Old 08-23-2003, 09:12 AM
Vetter
Also, when you do get a new cam, you have to watch. Believe it or not, this affects very many things. You can't just change the cam, and forget about everything else. For instance, a carb is highly affected by the cam. If it has vacuum purposes, the cam can alter vacuum at difference levels, therefore altering the carb.
Just some things you need to keep in mind.
78SilverShark
