lift and duration on 305 cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2010, 07:40 AM
im building a 305 to go in a jeep im boring it .030 over and i want it to have a lot of torque what cam should i use and also what should i do about spring and rockers
Old 05-27-2010, 11:23 AM
what engine is currently in the jeep?
Old 05-27-2010, 01:39 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Do you have a 2 Pc. rear main or 1 Pc. rear 305? If it is a 1 Pc. rear main roller cam block I recommend the '395 (last 3 numbers of the PN) Marine roller cam which was also used in the Ramjet 350 and HT383 crate motors. It looks pretty mild on paper but it's good for 340 FWHP and 400+ FtLbs FWTQ from 2,000 through 4,000 in an 8.7 to 1 350 with L31 Vortec heads. I'm putting together a 305 for a '66 C10 Chevy with this cam and 305 Vortec heads, it should be in the ballpark of 320 FWHP @ 5500 with 360 FtLbs at 4000 but the TQ is above 335 from 2,000 through 5,000 RPM. Not a TQ "monster" but not bad for a 305. For comparison a stock 70's 350 4 bbl. made peak TQ of about 320 at 3,000 and was down to under 270 by 4,000.
Old 05-28-2010, 11:00 AM
its got the 4 cyl in it now
Right cam for a 383? atomicrockerdude Engine 22 11-02-2009 12:13 AM
Solid Camshaft lift and duration changes...fusterated 357cutlass Engine 21 04-13-2009 12:02 PM
Roller Or Flat tappet 434 stroker ChevyThunder Engine 55 10-27-2008 10:17 AM
305 heads on a Chevy 307 75Guy Engine 6 04-30-2007 09:58 PM
305 cam carb manifold stickshift Engine 6 04-12-2005 03:46 PM
