Lift Kits - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2005, 04:55 PM
HammerZ28's Avatar
Lift Kits
I want to jack up the back end of my 1981 Camaro Z28 and there two different kinds. A suspension lift kit and a body lift kit. Which is better?
Old 12-17-2005, 07:27 PM
lift kit
ok one you cant use a body lift two it depends on what type of suspension it has i cant exatly remember so here it goes if it has leaf springs you could use a longer shackel or spring block if you have coil springs you can use a poly urathe spring spacer you will allso need to extend youre shock mounts
Old 12-17-2005, 09:03 PM
frankenstang57's Avatar
waynenewtoneVil
Last journal entry: plans
'81 Camaro=leaf springs. Shackles, the cheapest way to do it. If you're really ambitious, you can have the rear springs re-arched at a spring shop for a few bucks.
Old 12-17-2005, 09:26 PM
poncho62's Avatar
Wiki Edits: 5
Looked at the picture in your album....I think it sits just right. If you lift the back end, it will affect the handling and ride.
Nice looking car by the way... Did you buy it that way or build it?
Old 12-18-2005, 09:33 PM
HammerZ28's Avatar
I bought it like that!!
And Thanks
Lift Kits PeanuttMNMs4me Suspension - Brakes - Steering 7 02-23-2011 10:57 PM
Lift kits for 2002 chevy 1500 derrick3422 Suspension - Brakes - Steering 1 12-17-2005 07:31 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Hood lift kits Mr Monkey Body - Exterior 2 06-07-2002 12:21 AM
