Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lift Laws
Thread: Lift Laws
Old 11-09-2009, 04:12 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
It can vary WIDELY depending on the particular vehicle in question, sure you aren't going to be able to lower a car as much as a full size truck.
You aren't going to need to lift a full size truck as much as a small truck to achieve the same effect.
THEN, there are those that would like to install 44 inch tires on a mini truck and run it on the streets, the main reason behind lift laws IMO.
UPDATE, after a short online search I found the following:
MO has a bumper height law:
Regular vehicle 22 front and rear
Commercial vehicle up to 4500# 24 front 26 rear
Commercial vehicle 4501-7500# 27 front 29 rear
Commercial vehicle 7501-9000# 28 front 30 rear
