-   -   Lift Laws (http://www.hotrodders.com/forum/lift-laws-167894.html)
chevythmpr 11-04-2009 08:28 PM
Lift Laws
Does anyone know what the limit is for lifting your vehicle in missouri?
matt167 11-04-2009 08:58 PM
search your state DMV's site for " headlight height " and figure it out
campracing 11-09-2009 03:33 PM
I know around here you can not alter ride hight up or down more then 2 inches but they don't enforce it.
chevythmpr 11-09-2009 04:12 PM
I know you can add a lift and they measure by bumper hieght, but just not sure what the numbers are.
M&M CUSTOM 11-09-2009 04:12 PM
It can vary WIDELY depending on the particular vehicle in question, sure you aren't going to be able to lower a car as much as a full size truck.
You aren't going to need to lift a full size truck as much as a small truck to achieve the same effect.
THEN, there are those that would like to install 44 inch tires on a mini truck and run it on the streets, the main reason behind lift laws IMO.
UPDATE, after a short online search I found the following:
MO has a bumper height law:
Regular vehicle 22 front and rear
Commercial vehicle up to 4500# 24 front 26 rear
Commercial vehicle 4501-7500# 27 front 29 rear
Commercial vehicle 7501-9000# 28 front 30 rear
