Lift Laws - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2009, 09:28 PM
Lift Laws
Does anyone know what the limit is for lifting your vehicle in missouri?
Old 11-04-2009, 09:58 PM
Wiki Edits: 31
search your state DMV's site for " headlight height " and figure it out
Old 11-09-2009, 04:33 PM
I know around here you can not alter ride hight up or down more then 2 inches but they don't enforce it.
Old 11-09-2009, 05:12 PM
I know you can add a lift and they measure by bumper hieght, but just not sure what the numbers are.
M&M CUSTOM's Avatar
Wiki Edits: 9
It can vary WIDELY depending on the particular vehicle in question, sure you aren't going to be able to lower a car as much as a full size truck.
You aren't going to need to lift a full size truck as much as a small truck to achieve the same effect.
THEN, there are those that would like to install 44 inch tires on a mini truck and run it on the streets, the main reason behind lift laws IMO.
UPDATE, after a short online search I found the following:
MO has a bumper height law:
Regular vehicle 22 front and rear
Commercial vehicle up to 4500# 24 front 26 rear
Commercial vehicle 4501-7500# 27 front 29 rear
Commercial vehicle 7501-9000# 28 front 30 rear
old inground hydraulic lift wont go down wheel-7 Garage - Tools 16 05-27-2012 01:22 PM
America's Pride Lift Ampro, whole sad story [long] kgus Garage - Tools 106 04-13-2009 06:59 AM
Cams- Flat tappet & Roller-- Are lift and Duration figured the same? Lloyd1wv Engine 9 01-01-2008 08:36 AM
Warning fellow rodders of this 4 post lift truth be told 427 Garage - Tools 8 09-17-2007 10:48 PM
Lift Kit CustomFord Suspension - Brakes - Steering 1 05-09-2006 04:21 PM
