lifter bore grooving tool - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2009, 02:59 AM
usmcsawgunner's Avatar
so im doing my first cam install into my 350
i was wondering, since all the 350 internals are in if i would have enough clearance to use the grooving tool when i pull out the cam and other necessary stuff for the cam swap.
also is it worth it as far as camshaft longevity and if thats a tool that can usually be rented....id rather not pay 150 for a tool i'll only use once.
thanks
Dean
Old 03-07-2009, 04:50 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I wouldn't do any grinding on a partially assembled block. If you can not thoroughly clean the block after, I wouldn't consider it.
Just use a break in additive after installing the new cam.
Removing lifter bore rust. stroker_SS Engine 4 05-22-2006 08:38 PM
big block chevy "tall" lifter bore BBCMudbogger Engine 3 12-07-2005 08:19 AM
351 W Lifter Bore LilSmoke Engine 1 08-17-2005 09:48 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
how to prepare a block blndweasel Engine 14 08-15-2003 12:28 PM
