Lifter Noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2004, 01:57 PM
bluesman123's Avatar
Lifter Noise
I looked in the knowledge base and didn't find the answer. My 1998 5.7 Vortec has what sounds like a lifter tick when its cold at idle. After it warms up the tick goes away. The engine has low miles (under 20,000) and is totally stock. It has hydraulic-roller lifters (of course) and I run Redline oil.
1. Should I worry about the noise?
2. If this is caused by a sticky lifter, is there a way to cl;ean it...like with Miracle Oil or something?
Thanks for the tips,
Dave
Old 10-05-2004, 07:32 PM
Restore60s's Avatar
Engine Noise
If you have not got the problem fixed, go to your GM dealer and get a bottle of engine oil supplement. See if that takes the noise out.
Old 10-06-2004, 07:08 AM
DoubleVision's Avatar
What restore suggested will work, as will Sea Foam, which should be avalible at your local parts store. pour it in the oil, let it idle 20 minutes, change the oil and filter.
Old 10-06-2004, 11:08 AM
Thanks Restore and Dblvision. I'll give it a try next time I change the oil. I just changed it and went to Redline 10-30 and a K&N flter vice Redline 5-20 and a Fram filter. It seems to be better but it still ticks noticeably when it is cold.
Dave
