Lifter Noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2006, 09:20 PM
Lifter Noise
im having lifter noise after i shut engine off. seems to run great installed new heads intake carb same lifters as before... every time i shut it off it makes like 3 or 4 ticks and then stops adjusted valves like 3 times to make sure then when running it is fine ........chevy 350 79 z28
Old 08-01-2006, 06:40 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
How many miles on the engine and are you absolutely sure the ticking is coming from the lifters?
Old 08-01-2006, 08:54 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
not sure I am reading this right , but the first thing that comes to mind is a heat shield cooling off some where, header , starter, muffler type of thing. Never heard of lifers making any noise after the engine has stopped turning. but then again we are talking about a machine
Old 08-02-2006, 12:01 PM
Lonestar's Avatar
A case of Deja Vu?
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Lifter Noise karma69 Engine 2 08-02-2006 11:13 AM
lifter noise karma69 Introduce Yourself 1 07-17-2006 07:56 AM
lifter noise bamfasm Engine 2 07-26-2005 06:33 AM
Lifter Noise bluesman123 Engine 3 10-06-2004 11:08 AM
