Lifter rotation after cam break in - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2007, 05:31 PM
Chevtec's Avatar
New Member
I just finished breaking in a SBC 400 with a hydraulic cam according to the manufacturer's instructions. I used EOS and Rotella oil for the break in, and broke in the motor for 25 minutes. Now, I have a question. I pulled the valve covers off to readjust the valves and put marks on the pushrods with a sharpie. Using a remote starter to turn the motor over, I noticed that all the pushrods were turning, but at a MUCH slower rate that before the engine was run. Before, they would spin almost an eighth of a turn (or so it seemed) while turning the motor over by hand. Now, the pushrods rotate much much slower as the valve is being opened and closed.
Question: Have I done significant damage to the cam and lifters or am I just being paranoid?
I used a ton of moly lube on the cam and lifters, and when I drained the oil, it was rather cloudy (as if it was lube mixed in with the oil). Is this normal after a break-in?
Thanks in advance for the help!
Old 09-30-2007, 06:13 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Well I would not worry too much for things loosen up & lube up as the hours add up .
You should be able to spin them in between your index finger & thumb when the valve is closed {most of the tension off the push rod}.
Don't Worry
I have Enuf Paranoia for dozens of people. If nuthin is knockin or screaming you should be O K
"SlowRide66"
"Illegitimis non carborundum"
Old 09-30-2007, 06:40 PM
Jmark's Avatar
Yes....
and
Yes...
Old 09-30-2007, 08:58 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Everything you're talking about is perfectly normal. Before break in, the lifters and cam lobes were "rough" and they spun much more on the high side of the lobe. After they've been smoothed out by breaking it in, there is less friction there to turn it. Heck I have a few engines that the lifters don't turn at all anymore.
Cloudy oil is break in lube, machining dust, and other crap. Its normal.
Drive it.
Old 10-01-2007, 06:53 AM
Chevtec's Avatar
New Member
Thanks for the replies guys. I don't build motors very often, so, naturally, I don't have the vast experience to understand what looks right when it gets down to this level of detail.
Incidentally, I ran a pick-up magnet through the cloudy oil I drained last night, and no matter how hard I tried, I couldn't get the magnet to pick up any metal filings anywhere.
Well then, it's time to start tuning her for the street!
Old 10-01-2007, 10:38 AM
King of my Man-cave.
If you don't have one in it already, put a magnetic drain plug in it. That way you can monitor the oil at regular intervals.
tom
Cam break-in and zinc Frisco Engine 34 03-13-2007 08:22 PM
building a 1935 5 window coupe gunnulf Hotrodding Basics 8 06-28-2006 06:43 PM
sucessful cam break in- what oil to use ? fast68 Engine 8 11-21-2005 10:28 PM
Cam shaft break in stroker 58 Engine 5 10-14-2005 06:14 PM
hydrolic lifter cam vs. solid lifter cam chevyelc81 Engine 12 09-09-2003 07:38 PM
