Lifting 32 Ford 2 Dr Sedan body - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2006, 08:19 AM
Last journal entry: Bringing home the 401 Nailhead
I am redoing my 32 Ford 2dr sedan (all steel) and currently have the body off of the frame. Doing mock ups I can for see that I will have to reinstall/remove the body a few more times. Buddies are all getting too old with bad backs, sons are over the road drivers and for some strange reason wife says "no more help". Guess I am basically on my own.
Can I take a fork lift with the forks through the window openings (side to side) and lift? The body is solid but still wonder if this will put too much strain on posts.
A few of the posts that I have researched mentioned similiar lifing techniques but none were similiar body styles.
Old 11-01-2006, 08:54 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
If I were to use a Forklift I think I would wrap the Forks with Carpeting to take the "edge" off of the Forks so as to not damage the Roof-if the Fork Tines are long enough no reason it wouldn't work-
Old 11-01-2006, 09:01 AM
powerrodsmike's Avatar
Wiki Edits: 161
I would use the forklift to pick it up, but not with the forks through the window.
Get a couple of those wide straps for lifting/pulling and run those through the window openings, then hook to the forklift tines. The strap won't tear up the sheetmetal.
Later, mikey
BE different....ACT normal.
Old 11-01-2006, 10:46 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Looks like this Model T with frame attached was lifted by a fork lift. See far side.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Name:	26 T tudor.jpg
30 ford sedan madness??? MustBnuts Introduce Yourself 18 06-25-2007 12:07 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Matching hood to body '32 Ford cares Body - Exterior 13 06-05-2006 11:15 PM
39 & 40 Ford body? Gene Boyd Body - Exterior 1 03-01-2002 04:17 PM
32 Ford Coupe Body LoTempio Body - Exterior 4 01-29-2002 12:03 PM
