Lifting 63 lemans rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2011, 08:51 PM
I have a 63 Lemans the wheels i have on it look great and tuck under the rear fenders very nicely. Problem is i get a little bit of wheel rub when i hit a bump. I am going to be re-doing the suspension in the near future and will fix the problem properly then but for now i just want a quick cheap fix. I don't want to change coils or wheels as these look great. Any ideas how i can lift this just a little i don't really care if its not proper just want to use it for a few months till i take it apart again and do it properly. Thanks in advance to anyone that may have a idea.
Old 05-14-2011, 09:10 PM
Spring spacers and shock extenions.
Old 05-14-2011, 09:43 PM
I thought about shock extensions would they work on there own? I thought they would just effect the way the shock travels? I will look into the spacers. Thanks
Old 05-14-2011, 10:21 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Can you modify the bump stops a bit..they should be located on the frame above the axle and are there just for that purpose to stop the axle travel before the tires contact the car in any way.
Sam
Old 05-14-2011, 10:37 PM
Sam
Thanks i will take a look but not sure this car would have bump stops? These cars were originally trans axle cars, this car has been changed over to a coil spring rear. I will take a look tomorrow. Thanks
Old 05-14-2011, 10:40 PM
Wiki Edits: 3
If it does not you can get a pair at the local pick-a-part and install them..should have them anyway no matter what you do with the rear suspension..
Sam
Old 05-18-2011, 05:19 AM
SSedan64's Avatar
You could use a Fender roller on the inner Fender lip if that's where it's rubbing.
Pic of tool>> http://www.google.com/search?hl=en&q...w=1003&bih=619
There's a member on TurboBuick.com/forum that rents his tool out. If you're interested I can post the link.
Is that the "My Cousin Vinny" IRS rear suspension?
Old 05-20-2011, 03:33 PM
You DO realize that your 63 uses swingarm rear suspension. Lifting it screws up the camber, resulting in a very poorly handling car and causing irregular wear to your tires.
Old 05-20-2011, 05:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Had the flexible "rope drive" shaft that connected the engine back to the transaxle assembly. It was actually a length of relatively small OD steel shaft, not stranded like a rope of any sort. Could be tough to modify today, although back when they first came out, Pontiac raced the transaxles (modified, obviously)- using 421 SD engines, no less- in A/MP.
Below is the manually-shifted 4 speed automatic used in the SD cars.
Left to right (i.e. front to rear in car) : Tempest driveshaft nose (iron), Tempest Powerglide (alum), Tempest/Corvair differential housing (iron), 2nd Powerglide (alum), starter/flexplate/pump.
Photo from http://www.locostusa.com/forums/view...t=4968&start=0
Lifting an LT1 oldguy829 Engine 5 12-15-2009 09:08 AM
Everything is lifting Derkyb Body - Exterior 6 09-05-2008 07:53 AM
Lifting a car? ZZ4fbody Garage - Tools 4 02-23-2007 08:53 AM
65 lemans gto rear window rust pi71 Body - Exterior 2 07-05-2006 08:52 PM
Posi Rear for my 1971 LeMans flh77rat Transmission - Rearend 4 03-08-2005 05:49 AM
