lifting cab 50 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2007, 04:46 PM
71corvette's Avatar
what is the best way to lift the cab on a 1950 chevy 3100 pickiup? where do you put the straps? I was thinking off running them under the cab where it sits on the frame. I dont want to damage or bend anything. the cab is empty and the doors are off. I will lift it with a chain hoist
Old 12-19-2007, 05:37 PM
use a 2 by 12 as wide as your cab at where the top of the doors shut .
use a strap at ends of board .
you can use a cherry picker and place the boom under the board and jack it up off the frame .
Old 12-19-2007, 06:44 PM
71corvette's Avatar
I thought about that but was not sure if it would bend the cab roof or not. I have a chain hoist set up in the shop so that will be easier. thanks
Old 12-19-2007, 07:00 PM
31 five window
Last journal entry: grill and rear end
Burntolds is right,thats how we lifted a 65 chevy, works great and no damage.
Old 12-19-2007, 07:12 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
We just picked up my 48 Chev 1/2 ton the same way with no problem. Also, the doors and front glass were still installed.
Old 12-19-2007, 07:41 PM
Originally Posted by 71corvette
what is the best way to lift the cab on a 1950 chevy 3100 pickup
Just invite a few friends over ... no damage from chains, straps or boards. In this photo WE were putting the body back on ... but the principal is the same.
I built a wooden dolly with a good set of wheels on it ... to set the body on.
Old 12-19-2007, 08:16 PM
Last journal entry: '50 Chevy pickup
Try using your cherry picker like I did.
I wrapped a tow strap through the open window openings on the cab and brought the two hook ends up to the exterior top of the cab where I attached them to my cherry picker with the boom extended (as well as the legs). That raised it up enough to take the cab off sideways. Leave the doors in place for strength. I'll try to send an image or two.
Duggeroo
Old 12-19-2007, 08:19 PM
I wrapped a tow strap through the open window openings on the cab and brought the two hook ends up to the exterior top of the cab where I attached them to my cherry picker with the boom extended (as well as the legs). That raised it up enough to take the cab off sideways. Leave the doors in place for strength. One man can do it alone this way. I tried to attach an image and failed. Email me and I'll send pics of the easy one-man way.
Duggeroo
valleymedical@embarqmail.com
Old 12-19-2007, 11:00 PM
Mrwood's Avatar
Last journal entry: My 1962 Falcon
re: lifting cab 50 chevy
Well the cab of your truck is alot less weight than my 48 chevy fleetline body. I used some 4x4s went through the windows, and had a friend with a tractor lift the body up and on to some saw horses. Did not hurt a thing, and it cost me a six pack of beer. He did the same thing when i put the body back on.
Old 12-19-2007, 11:38 PM
71corvette's Avatar
Duggeroo
the doors were already off the body when I got it
Old 12-22-2007, 05:31 PM
chevy3600's Avatar
http://community.webshots.com/
With the cab on my Chevy 3600 I used workers that will do jobs no American will do.
Old 12-22-2007, 05:35 PM
This works.
Name:	JD lifting.jpg
Old 12-22-2007, 09:27 PM
71corvette's Avatar
got it off
I lifted the cab off today. I used my chain hoist and a 2x12 with a strap. very easy and it went smooth
1936 Chevy pickup cab wood referbish donlp Body - Exterior 6 12-14-2010 05:27 PM
inline 4.3 50 model chevy truck ltlvt Engine 1 09-11-2007 10:35 PM
Fuel Tank for 50 Chevy P/U DirtDoctor Hotrodding Basics 8 01-14-2006 07:43 AM
1935 chevy pickup cab wood 1955chevy Body - Exterior 3 12-13-2004 10:23 PM
88 chevy 2 ton cab to 80 3/4 ton frame stoneyone2001 Body - Exterior 1 11-11-2003 09:43 AM
