Lifting points on a ford 4.6 sohc ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2010, 05:31 PM
Old Fool's Avatar
I need to pull the engine out of a 2001 Mustang GT. I can't drop it out the bottom.
I am wondering the correct attachment points for lifting the engine.
I don't see any obvious attachment points without making brackets to bolt onto the engine.
Anyone have experiance with this application?
Thanks in advance
Old 04-16-2010, 05:57 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
4.6L Engine Swap pics
Find some good sturdy bolt holes on the block and push a bolt w/ washer through a link on the chain and thread it into the bolt hole. Make sure it's balanced in such a way that you can pull it out. I would probably remove all the plastic/easily damaged components first and triple check that you've removed EVERYTHING that connects the motor to the chassis (including fuel/electrical) before pulling it out.
If you do a google search you'll find that the removal of the SOHC 4.6L is a pretty common occurrence on mustang forums, it might provide some additional help.
Ford 4.6 DOHC JdOwNj Engine 13 01-08-2011 09:47 AM
ford 4.6 2v piston to valve clearance sheldonw Engine 1 07-30-2008 01:39 PM
Ford 5.0 & 4.6 bolt patterns deleteall Engine 1 06-29-2003 04:25 PM
4.6 Ford timing pontiac man Engine 1 01-22-2003 02:53 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
