LIGHT bulb blows fuse! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2006, 07:04 PM
bullheimer's Avatar
NEVER use credit cards!
tried about 10 fuses and traced all my wiring for my tail lights (leds) to no avail till i pulled out the license plate light cause the enclosure was wet. poof! my lights all worked.
now i have to ask....WHY? the light still worked. had 1 ohm resistance, burned VERY brightly for a half a second till the .5A fuse blew. i don't get it. the bulb has been in my truck for about 8 months.
Old 11-08-2006, 07:34 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Was the Tag lamp An incandescent? If so, Most likely it was on the ragged edge of resistance (filament resistance) to ground for the lighting circuit..Causing a higher draw with all the other added lighting resistors.
blowing the fuse when it was wet..was probably an additional resistance added to the mix and put it over the edge..
You COULD try a 1N4001 Diode on the tag light power...see if that doesn't cure the problem, If not raise the fuse value by a few amps..and worst case, you could use a relay to control the tag lamp.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 11-10-2006, 09:35 PM
bullheimer's Avatar
thanks doc. hope yer doin better
Old 11-10-2006, 11:24 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
No Sweat!
Gaining more and more health each day! got my meds straightened out and more and more ambulatory each day!
Thanks!
Doc
Innovations
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 10:02 PM
How many Forum members.............. Stitch Hotrodders' Lounge 29 03-11-2004 07:31 AM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 03:39 AM
a little humor to get through the evening antirice Hotrodders' Lounge 7 08-28-2003 08:36 AM
Fuse blows Horn dome light and the back hatch th2hh Electrical 3 08-24-2003 07:44 PM
