light rust on floor boards, wwud?
i'm starting on my 59 rambler prodject and there is some rust on the floor boards, so far the floor are in ok shape and not rusted through. what do you guys recommend to do, should i clean the rust off with a rust remover like naval jelly or similar product? or should i use a rust converter or paint on it?
rusty floors
Hi,i would put OSPHO on the rusty floors,after the rust is gone (turns black)clean the floors LIGHTLY with 320 paper,then spray or brush floors with 2k epoxy primer,maybe 2 good coats,then paint,or carpet,your choice...
To prep the floors properly, you would need to knock the rust down, wire brush on a drill works well, get ALL the loose rust out, then use some epoxy primer. Basically what you want to do is seal the surface so you don't get the rust back, a couple of coats of epoxy will do this. Ospho, Por15, all do the same thing but why would you risk failure if the Ospho isn't neutralized properly, Por15 is expensive and hard to overcoat. You can get the same results with epoxy primer for less money. But, no matter what you do, if it is not prepared properly, it ain't gonna work.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
I always let my epoxy primer dry overnight or longer if I can before I put on 2-k primer. I also scuff well with a red scuff pad or lightly hit it with some sand paper.I would think in az you may get by with less time. I managed a shop in Phoenix, az in the late 80s and it was great the way paint set up out there.
I know what shop temps you have to deal with back there. Also the issue of rust! :-( I moved here from the upper Midwest in '75. It's a dry 78 here today. :-) |
A lot of shops wait long enough to mix up the 2-k and then go at it [will not work well.] Even with shop heat in winter here it takes a while to set up good.I loved the weather in az when I was out there. Although we cant kick about the winter we had this year here. It was 66 today and is suppose to be in the 70' the rest off the week. Didnt have to clean the drive of snow one time yet this winter to my shop. As I said liked the weather in az and loved the area just didnt like the right to work state part. Tanslates to I have a right to pay you as little as I can get by with. Managed a small shop off cave creek rd in phoenix 86-88.
I do prefer the removal of rust other than just painting over it. I always felt that if there was rust under the paint it could still spread.
like boatbob said get rid of the rust . if blasting is not an option naval jelly will remove it but you must rinse the jelly off BEFORE it drys . once clean seal it up with 2 coats of epoxy and your good to go. slight surface rust is not a big problem but painting over scale rust is bs period.
and i use only epoxy on jobs. no urethane primers at all. |
| 47 chevy Floor Boards | eheine20 | Body - Exterior | 2 | 06-19-2010 09:37 PM |
| insulation UNDER floor boards??? | yragat | General Rodding Tech | 7 | 04-02-2008 04:43 PM |
| floor boards and doors | Beau Bishop | Body - Exterior | 2 | 09-13-2005 10:17 PM |
| Adhesive Floor Boards | tay | Body - Exterior | 5 | 03-07-2005 08:04 PM |
| Rust on the floor boards | Jackyl | Body - Exterior | 3 | 09-21-2004 01:28 PM |
