Light to show fan is on - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2012, 03:08 PM
I want to know when the radiator electric fan is on. I added a small 1/8" diameter 14v bulb (looks like an LED) in parallel with the fan. See attached pic. Works great when the fan is on, the light is bright and does let me know when the fan relay kicks in at 195*F. But it illuminates about 80% when the car is moving and the temp is below 195*F. The fan acts as a generator and powers the bulb. So I added a 1N4004 diode in series with the bulb and the result was the same. I reversed the diode and the light would not come on at all. The engine is carburated not EFI. So fellas, I need someone with electrical knowledge to help me out here. Please and thank you in advance.
Old 03-08-2012, 05:09 PM
T-bucket23's Avatar
Wiki Edits: 26
Feed the light power from a separate source and use the ground that gets pulled up from the relay to make the ground for the light.
Chet
Old 03-08-2012, 05:15 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Connect the pilot light parallel to the coil of the relay.
vicrod
Old 03-08-2012, 05:55 PM
The fix
Thank you for the replies. Following T-bucket23's suggestion, I connected the light bulb as per 2nd sketch. I jumper-ed the thermal switch to simulate 195* and it worked. The fan actually has enough momentum to generate the power. But I also place a house fan in front of the rad fan to simulate driving down the road and NO light. That's what makes this another great forum. Thank you fellas.
Cool light show... NEW INTERIORS Off-Topic 2 12-26-2011 12:27 AM
Dream Machine show is coming! May 1st NOT just a car show! MARTINSR Hotrodders' Lounge 4 04-19-2011 01:51 PM
Bad Stop light?(brake light) A-BodyFan Electrical 7 03-09-2006 04:19 PM
Auto show / freak show F1 Owner Hotrodders' Lounge 6 11-02-2005 03:38 AM
Nature's light show machine shop tom Hotrodders' Lounge 11 11-09-2004 06:39 PM
