Light tap noise when left hand turn is made - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2007, 01:18 PM
Have a 1967 Ford mustang with power steering and sometimes when making a left turn it makes a light solid tap that sounds like it is coming from the right side underneath the car. It does not do this when making a right hand turn. Could this possibly be the idler arm? Thanks
Old 11-27-2007, 04:08 PM
dtcandyman's Avatar
Last journal entry: Time to let go
Re:tapping noise
I'd check the stabilizer links. They are known for making a ton of noise in any car...
Old 11-28-2007, 10:18 AM
Light tap noise
Hello, thanks for the info. By checking you mean condition and torque on the end links? They are new, but didn't use a torque wrench. According to shop manual they are supposed to be 5-11 lbs on the end links and 17-25 lbs.for sway bar bushings to frame. As soon as weather warms up, I will check those.
Old 11-28-2007, 10:35 AM
poncho62's Avatar
Wiki Edits: 5
I would think that the stabilizer links would rattle more when you hit a bump rather than turning. I would think I would be checking my wheel bearings....maybe loose, maybe bad. Or, something loose in the brake drum.
Old 11-29-2007, 12:47 PM
dtcandyman's Avatar
trust me...i never thought stabilizer links could make such a noise...but mine did,just taking a turn at slow speeds...like while entering a parking spot.
Old 11-29-2007, 02:13 PM
Light tap noise
I was just out in the garage looking ay my sway bar and end links and am wondering if I put the sway bar in upside down. Looks OK but am not sure. Anyway, is there a way you can tell?
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Weird Light problems TurboS10 Electrical 6 11-03-2007 07:29 PM
left tail light flashing too fast 88 nova gal Electrical 7 01-21-2005 05:23 PM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 12:12 PM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 07:59 PM
