Light/Work area while porting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 12:30 PM
Silverback's Avatar
Boost Retard
What do you use as a light source while actually porting? Do you port on a table, bolt it to a stand, sitting down/standing up?
I've done a bunch of my own and have never been happy with whatever I ended up with. It seems like no matter what I do there is always something that I'm not happy about.
In general, I like being up above my work, but a bad back results in me taking short cuts when I'm standing so I prefer to be sitting.
I haven't quite found a surface that I like doing it on, generally something like my craftsman version of a workmate is best, but it gets in the way. I like my work held down but still easy to move. I've thought about bolting heads to an engine stand, that aught to give me better access to them, easily rotated... but the cheap stands that I have sitting around I suspect will move around too easily (I can put something on the legs to keep it from rolling around but I can't think of what would put enough drag on the head that I could still easily rotate it but it wouldn't tend to spin around while I work.
I've done a few manifolds where I was mostly coming at them from a few limited angles that I was quite happy with adding a crosspiece to the leg of a heavy sawhorse and then bungee cording it to the leg of the sawhorse, sitting on a stool next to it, but that wouldn't work at all for a set of cylinder heads.
I have a couple of desk lights/reading lights that I'm OK with, but inevitably I flip them over moving them around... typically I'll go through a couple of bulbs just knocking them over doing a set of heads. I have a florescent tube type drop light that I like how it lights up the ports holding it up against them or the chambers, but it's too big a hassle to use while actually doing the work.
What works for you guys?
Old 01-16-2011, 12:36 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
have you ever tried a set of safety glasses with the lights built into the sides?
Old 01-16-2011, 12:46 PM
Silverback's Avatar
Boost Retard
huh, no, always thought those things looked hokey... but come to think of it I do have a couple of "headlights" sitting around (it seems like I've gotten one for christmas every year for the last few years, I have one sitting by the stereo setup, makes things much easier when fishing wires in and out to the components...), I'll try that later today...
Old 01-16-2011, 02:21 PM
ericnova72's Avatar
More for Less Racer
I use a fixture that bolts to the bolt pattern on the end of the head, then fits into an engine stand that has a locking clamp, rather than just a couple of pin holes for location. I use some small bungee straps to strap a florescent light stick along the port openings to backlight into the port opposite from the end I'm working on. Works a lot better to backlight than to try to put light into the same side you are working from IMO.
I'm going to have to look into that lighted safety glasses idea, it might add a little in the right places.
Old 01-16-2011, 04:53 PM
DoubleVision's Avatar
I put the heads on a table. I clamp 2 lights directly above and I use a portable light at the mouth of the port I`m working on so it lights up the bowl area.
since I`m tall I sit on a stool that`s close to the height of the table, this is so I can be above it so I can keep a eye on the back of the bowl as I`m porting.
Work Area, Material Storage and Organization slodat Interior 6 01-18-2011 09:48 AM
how do i fix nova tail light area? andy_s273 Body - Exterior 2 07-01-2009 09:10 AM
Ever Need more light to work.. zapf Garage - Tools 16 07-12-2006 02:59 AM
porting 882s at home,no machine work, rebuild, will it work? what are they capable of Warrant Engine 6 12-27-2005 01:14 AM
Turning my dirt work area into usable space deleteall Garage - Tools 9 06-26-2004 11:30 PM
