Lighting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2007, 08:47 PM
Lighting problem
I have a 77 Chevy truck and last night encountered some lighting problems. I was backing down my driveway when I noticed I didn't have reverse lights. Come to find out I didn't have brake lights either. I did have my running lights though. After a brief search I discovered my turn signals didn't work either. Today on my way into work I stopped and got some fuses thinking that was the problem, but that didn't help either. Any suggestions?
Old 10-23-2007, 06:07 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Have you checked all the bulbs and sockets?
Old 10-23-2007, 06:09 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
If by any chance you have a manual trans----the back-up wires may rub on the z-bar thus shorting both the back-up and turn signals.
Another thing to look for---if you have tilt column----the wires inside the column WILL eventually break, could cause a short or just an open circuit.
I have had both issues happen to me, it is kind of weird that the tails/brakes/signals would ONLY work with the wheel all the way down.
As far as the back-up lamps-----everything will work UNTIL you put it in reverse --- then the fuses go bye-bye.
I have had the steering coulumn issues about 3x on my 79
Tilt is the most used option in the truck.
Bryan
Old 10-23-2007, 11:04 AM
Having many of these in the past it is pretty common for the rear frame ground to go bad. Have you checked that?
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 12 07-19-2007 08:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
Piston/valve interference problem jameskirk1 Engine 12 12-03-2004 04:14 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
