lights control the volume - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2007, 05:12 PM
Hello,
I am having a problem with my radio.When I turn on the dash lights with the headlight switch,the volume of the radio goes lower.When I turn off the dash light,the volume of the radio goes back to louder.
I really don't understand how it or why it is doing this.I have a 1977 Chevy nova.Could any of ya'll help me in my problem?
Old 06-06-2007, 06:22 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
It may be bad Grounding..Ground the radio to a Good Body ground.
Try turning The panel dimer up and down the full sweep with the radio on, If it goes off then on then louder..you have the radio power connected to a Panel Dim line..remove it and move it to a Switched Fused line.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Having problems with the tail lights... HammerGVette Electrical 3 04-17-2007 01:06 AM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
Theory: Intake volume vs cylinder volume / engine vacuum 59vette Engine 6 04-29-2004 12:03 PM
