start with checking the grounds
You need to geta voltage gauge and attach it and go for a ride. Most likely you will see the voltage go up when the lights are getting brighter. This could be several things. The first thing i would look at is that the battery ground is firmly attached to the block. Secondly, check the wire on teh #2 terminal of the alternator to be sure it is connected to a switched source close to the fuse panel. This is the wire that controls the charge rate for the alternator. If the problem is intermittent it may not show up on an alternator tester. I would check over the wiring first. Most weird alternator issues are caused by wiring issues. Check the body grounds also.
Artificial Intelligence is no match for Natural Stupidity Chet |
t-bucket.. I think you are assuming he has a newer internally regulated alternator. on an externally regulated alternator that his chevelle would have had stock.. both alternator wires go to the regulator mounted on the core support by the driver's side headlight.
| Help with tail/brake lights needed! | chewyscool | Electrical | 7 | 04-05-2009 08:38 AM |
| New wire harness. . . all my lights are acting funny | elcaminodragster | Electrical | 12 | 02-24-2009 09:47 PM |
| Having problems with the tail lights... | HammerGVette | Electrical | 3 | 04-17-2007 01:06 AM |
| voltage to tail lights vs brake lights? | stratt134 | Electrical | 12 | 06-10-2006 06:51 PM |
| Wiring Tail Lights & Turn Signals | horvath | Electrical | 15 | 04-30-2003 05:04 AM |
