Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lights I cant see!
Old 07-20-2006, 08:36 PM
adtkart adtkart is offline
I have a selection of flourescent lights in mine. I have both 4' and 8' lights in there. The more lights you can get in there the better. You should also have them on several switches. That way you could have only some on, if that is all that is needed. There will also be some cases where you will be able to see with some of the lights off.
