lights went out - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2005, 09:50 PM
New Member
lights went out
So i got home today, and realized my rear lights werent working at all, no running lights, or brakelights or anything.. alls that works is one headlight. Whats the cause ?? blown fuse or what.
im not really experienced in any car electrical systems.. car is a 67 camaro btw, if that matters.
Old 07-28-2005, 04:41 AM
302 Z28's Avatar
I would suspect a headlamp switch, unless there is some wiring malady.
Vince
Old 07-29-2005, 08:14 PM
Scotts67's Avatar
New Member
Need more info, what has changed since they "worked"? Have you installed an aftermarket radio, amp, speaker box in trunk? Sounds like probable ground problem but not sure to suggest where to start. Do turn signals work? Front or rear? Still have dash lights? Try some more info and we'll get you going again...
Old 08-03-2005, 09:38 AM
rrmccabe's Avatar
GM Muscle
[QUOTE=Velyx21]Whats the cause ?? blown fuse or what.
QUOTE]
Its not a blown fuse causing all the problems, but might contribute to some.
I would start looking for grounding problems first. The running lights and brake lights are two different circuits. The running lights come through the dash headlight switch and the brake lights feed from the fuse panel to brake light switch to turn signal switch and then back to tail lamps.
The headlights do not have a fuse but should have a CB. But since one is working this is not an issue.
As I said, start looking at bad grounds. You can get a 6' chunk of wire and attach to to the ground terminal on battery and start touching ground locations. Like where the headlight ground screws to body.
Old 08-03-2005, 03:11 PM
docvette's Avatar
Wiki Edits: 12
Fuses
Doc here,
Check the fuse for the tail/brakes first, see if they aren't blown.
Then turn on the lights and see if you have 2 high beems , If so replace the non working headlight.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
GM courtesy lights 78 monte Electrical 13 11-25-2009 05:48 PM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
Back Up Lights - how to choose? horvath Body - Exterior 6 03-04-2003 03:20 PM
EZ wiring harness, tail lights 53chev Electrical 4 11-05-2002 06:23 PM
my newborn crapped his die-dees: l.e.d lights all blew up bullheimer Electrical 4 08-16-2002 08:44 AM
