Just because it spins both tires sometimes does not mean that it has a LSD. Many times a standard differential will also spin both tires. The best way to tell exactly what you have is to remove the cover and look inside. This will require a oil change, but there is no other positive way to know what you have. You could have a LSD with worn out clutches, or you could have a standard differential with a galded cross shaft. I have seen a bent axle tube cause both tires to spin.
Any open diff will spin both tires if the loading is equal on both tires(say you are positioned just right on a crowned paved road), or if the surface gives easily like a gravel road, or on wet pavement. And everything else that Big Gear Head already posted. |
| limited slip or ratchet | kevin383 | Transmission - Rearend | 5 | 10-08-2009 11:04 PM |
| Limited Slip? Pic Inside | Dmaleck | Transmission - Rearend | 20 | 10-24-2008 05:29 PM |
| limited slip?? | saenz5 | Transmission - Rearend | 10 | 06-16-2005 09:29 PM |
| Limited Slip GM | schnitz | Transmission - Rearend | 6 | 06-25-2004 04:52 AM |
| Want to go from 2:43 limited slip to 3:73 limited slip | Bradless | Transmission - Rearend | 2 | 01-03-2003 10:12 PM |
