Limited slip - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2011, 05:46 PM
Limited slip
I just bought a 87 Monte SS from what I gather it has 3.73 limited Slip, although when I jack it up and spin one wheel the other wheel spins oppsotie way! I have limited experience on LS rear ends, is this normal, or could the clutch pack be gone? Oil? I know the guy that had this car abused it. Any help appreciated. Ty
Old 08-30-2011, 09:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Probably not an LSD. Could be, but doubtful unless there's damage or a lot of wear on it.
HERE is a link to help you tell what the gear ratio is if there's any doubt.
Or just give it a differential lube change. While the cover's off you will see the condition of the gears, whether or not it's a posi and what the gear ratio really is.
Old 08-31-2011, 10:05 AM
S10xGN's Avatar
Gotta love a turbo!
Although it would seem a natural for the MCSS to come with a limited slip (that would be the G80 option code), I've never seen it happen...
Russ
Old 08-31-2011, 05:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I agree↑X2. The closest to a "sure thing" I've seen regarding posi diffs, is the second generation Pontiac T/A. I believe they could be ordered w/o a posi, but came standard w/one as part of the package.
Limited slip? Mertz Transmission - Rearend 5 12-29-2010 09:59 PM
limited slip?? saenz5 Transmission - Rearend 10 06-16-2005 10:29 PM
Limited Slip GM schnitz Transmission - Rearend 6 06-25-2004 05:52 AM
posi from a limited slip? rhino Transmission - Rearend 1 02-28-2004 03:30 AM
Want to go from 2:43 limited slip to 3:73 limited slip Bradless Transmission - Rearend 2 01-03-2003 11:12 PM
