Limited slip differsntial rebuild questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 04:55 PM
I want to install a limited slip pig in my Ford 9" rear end but most of the ones I have found in my price range seem to be in need of a rebuild. Is this something I can do? Is there a manual available that I can follow step by step? What is the cost range of the parts? Any special tools required? Would I be better off to buy one that is already rebuilt?
That's a lot of questions, but I hope I can get some direction from the experts here.
Thanks
Old 07-07-2005, 07:09 PM
Try a Chilton's or Motor's book.These are only slightly more complex than an open diffy.Most carry a pack of clutch discs,similar to an auto trans.
350 Rebuild Questions chevyman06 Engine 1 06-22-2005 10:50 PM
Limited Slip and Posi noise 70bird Transmission - Rearend 7 06-04-2005 09:20 PM
7.5 Limited Slip POSI Aaron930 Transmission - Rearend 0 02-05-2004 09:18 AM
Ok, question on limited slip... Rubberman2003 Transmission - Rearend 5 06-07-2003 04:47 PM
Want to go from 2:43 limited slip to 3:73 limited slip Bradless Transmission - Rearend 2 01-03-2003 10:12 PM
