Lincoln AC 225 Arc Welder - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2010, 05:42 PM
What is a good all around stick number to use for mild steel?
One that will work on rust or dirty up to maybe 1/4" not looking for pretty just something I can have for repairs.
Old 06-25-2010, 05:52 PM
BOBCRMAN@aol.com's Avatar
6013 is the buzz box workhorse..
Old 06-25-2010, 07:01 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
6011 or 6013. one of the most important things is the care and storage of the rods. dry storage is a must. pre heating in a rod box helps too. i have had rods go bad in a short time in humid conditions.never let em get wet.dirt it real bad in a weld. rust itsn as bad but its allways best to have a clean surface.
Old 06-25-2010, 07:40 PM
Old Fool's Avatar
6011 will dig in more than 6013 and will handle some crud, which the 6013 doesnt do.
6013 is great for nice clean fillet welds and that is about it imho.
if you have a damp rod, just stick it to the weld metal for a few seconds, then break it loose, the heating of the rod will dry it out fast. Not like a new rod, but makes it usable again.
Old 06-26-2010, 05:05 AM
Race The Truck
Last journal entry: Son's Truck
I like 6011 myself 7018 is my next pick!
Craig
Old 06-26-2010, 10:30 AM
Wiki Edits: 31
I use 7018 for most everything on an ac 225.. if I'm using my dads 110v buzz box, the only thing it will burn is 6013 3/32" but it does very well with it
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Lincoln MIG Welder Problem 1930u Garage - Tools 11 09-22-2008 02:22 PM
Miller Thunderbolt 225 AC Welder Strictly Gravy Garage - Tools 15 02-17-2008 11:26 AM
question about older arc welder...Miller bigbadbowtie Garage - Tools 4 11-01-2005 10:13 PM
Arc welder ~VS~ Mig Welder ChrisMiddleron Electrical 15 07-08-2003 07:31 AM
