Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lincoln electric welder
Old 08-25-2009, 06:26 PM
jasrking jasrking is offline
My weldpack HD100 just stopped did not have an arc and it would not push any wire. I read through the troubleshooting guide in the manual. It said check the reset button to see if it was pushed out. negative. Then it said to check for faulty because you can hear the machine get the signal, the wire just doesn't feed..due to the fact that their is no arc it is obviously something way beyond a wire feed then said the machine can shut itself down due to was on for only five minutes and i only struck several tack welds with it before it stopped on a 75 degree day. i opened the machine up and heard a rattle...turned out to be a small one inch piece of metal that fell off of who knows what..can't tell what its purpose was other than maybe it held a wire..cannot find any loose wires however....i have owned this machine for 20months and only used it a handful of times...i believe the warranty is only good for a year..anyone have good luck with lincoln electric taking blame and fixing a faulty machine after the warranty is up?? (in my humble opinion a piece of metal falling off the inside when it is sitting on the ground untouched is faulty)
