Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lincoln electric welder
Old 08-25-2009, 09:53 PM
jasrking jasrking is offline
fan runs...ok i just went to try it again..nothing until i fiddled with the settings knob...if i pull the knob out (remember i said it was a little loose) it started feeding wire.....of course then the wire got stuck while feeding through right where the handle curves..but that's no apparently there are contact points on the knob that must be not contacting?? am i correct?
