Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lincoln electric welder
Old 08-26-2009, 11:57 AM
boatbob2 boatbob2 is offline
boatbob2
lincoln welder.
Hi,i have 2 lincoln welders,if you use them to tack,sometimes you will get a haystack between the end of the housing and where the wire goes. turn the set screw out and pull the cable housing out ,and you will see the haystack at the welder end of the cable(actually between the cable and where the cable goes into the feed roller) using side cutters,cut the wire out,pull the wire thru the end,and reinsert the wire. it may work then. my welders are almost 15 years old,and other than the haystacks (maybe 15 times in 15 years) ive never had a problem.
