Lincoln engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2006, 06:58 PM
Lincoln engine
I have a 1978 Lincoln town Car with 70,000 miles and it's in great shape. My son wants the engine (460 or 466 CID) for a hot rod and was told he can retrofit in onto a 40 Ford chassis. Any truth to that? Is a Lincoln engine any good in a hot rod? Is the car worth more as is?
Old 02-20-2006, 07:41 PM
BOBCRMAN@aol.com's Avatar
The motor will be a 460 Ford. A very good LARGE engine. These are good hot rod motors if you can handle the gas milage of big engines. Yes they have been fitted into pre-war Fords. NOT a bolt in, but, they do make a good running, powerful motor.
Old 02-21-2006, 01:05 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
460 with a C-6 transmission:
large, heavy, low compression, low power, poor gas mileage, expensive to hop up, poor heads, needs a full suspension upgrade front and rear,
solid, dead reliable, run many miles, impresssive looking in a rod.
Probably be a bear to cool in that 40 engine comparment.
I'd swap the whole car for a 5.0 HO fuelie and AOD from a Mustang. It would be lighter, faster, handle better, cheaper, and get 22+ mpg easily with the AC on. OH, ya, did that to 40 tudor.....
Old 02-22-2006, 11:54 PM
View 24 albums at Moes Garage
The 460 wakes up real fast if you order a 1970 429 timing chain and gears for it. Thats 30 hp right there. A Very good cam was available thru Ford motorsport for $69. A dual plane intake and some head work and you'll be into 300 horse power cheaply. The 429/460 can be made to run reliably with massive torque and good hp. They are really not that expensive to build or make hp with, -if you research your parts and sources.
moe
http://spaces.msn.com/moes-garage/
ENGINE BALANCING NAIRB Engine 22 01-23-2016 01:44 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Mystery Engine altonas Engine 3 04-17-2005 04:54 PM
