Lincoln gas powered welders - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2005, 04:37 PM
Does anyone own or has used the Lincoln Electric Portable 125 amp Welder/5500 Watt Generator Model K1429-8, If so what do you think of it? I know it is only 125 amps of welding power but I need to do some fence work as in corner post's etc. Also is the generator o.k.? Thanks
Old 08-17-2005, 05:17 PM
Great little welder! The thing is it is just that, a little welder but if that is all you need it is a fine outfit and parts and service, if you ever need it, is easy to find. If you are thinking about buying a new one, have you checked out the Lincoln Ranger series? Not a great lot more expensive but a lot more power with 225 welding amps and 8500 watts of generator power(120 volt and 220 volt). OK you asked about the 125 amp
Old 08-17-2005, 05:49 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I ran a price check and the price of the little one is 2/3 the price of the larger unit..I think I would hold out for the larger unit if possible..much more use for the larger unit..
Or one could shop weld the pieces for field installation...
OMT
Old 08-17-2005, 08:08 PM
I have a Ranger 8 with 20 HP Kholer on my field service truck and it is one fine outfit! The MIG function when hooked to a wire feeder(LN 25) is as good as any shop unit I have ever tried and with scratch start TIG equipment it works just as good. I have had this welder for 6 years now and it is used about every day with zero problems so far. I know of one guy who runs a well drilling rig and he uses the little 125 every day and swears by it. Which ever rig you chose I think you will be happy with it.
Old 08-18-2005, 01:21 AM
OMT
Home depot has the Lincoln 125 amp gas driven welder $1149.00, about $350.00 cheaper than Lincolns suggested price on their web site. I do have ARC, MIG, TIG and O/A in the shop and could weld the pieces for field install but some of the fencing is in ground now and need some repairs. I was thinking of convenience in the field. I really don't think I need a larger welder for what I am wanting this for.
Gas Thieves!!!! Weimer Hotrodders' Lounge 28 03-03-2010 02:46 PM
gas prices 69novarodr Hotrodders' Lounge 27 04-17-2009 09:47 AM
Lincoln HD 100 gas conversion troubles ComingApart Hotrodding Basics 0 07-14-2005 08:21 PM
Gas Tank .... problems 63novawagon Body - Exterior 1 04-25-2004 11:26 AM
want cheaper gas prices?? plz read this sherfield2002 Hotrodders' Lounge 7 03-12-2004 05:22 AM
