lincoln keyless entry - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2005, 12:21 AM
71 c-10's Avatar
just a kid and his truck
my buddy has a 94 Lincoln Continental and it has that number pad on the drivers side door. He just bought it from a neighbor but they don't know the code. some one told me you can find the code in the trunk?? If so is there a possibility it could be changed or something?? I dunno why he wants to know so bad, hes got the remote for the thing, i dunno, hes one of those dudes if hes got it he uses it. Thanks for the help.
Old 10-12-2005, 05:07 PM
Wiki Edits: 31
you have to program the code, it is not set even from the dealership or factory, If you have the owners manual just reset the computer ( disconnect battery, turn ign on, turn off, reconnect battery and turn ign on ), then follow the instructions to reset the code.
Old 10-12-2005, 06:39 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
The permanent door code is on a white tag on the deck lid hinge and not user changeable. If the permanent code does not work, the car computer may have been changed. You will have to go to Ford for resetting it on their master computer.
Installing a personal key code is covered in the owners manual.
Key fobs are easily programmable to match the fob to the car computer, any dealer (or anyone with the procedure) can do it.
Old 10-12-2005, 07:42 PM
71 c-10's Avatar
awsome thanks a lot ya'll. So from what i understand there are two diffrent codes? One standard that is on a tag in teh trunk, and one that can be progamed? i'll let him know thanks again for the replys
Old 10-13-2005, 01:24 PM
xntrik's Avatar
correct, personal code programing is in any ford owner's manual
Old 10-13-2005, 01:40 PM
71 c-10's Avatar
thank you very much
Old 10-15-2005, 08:33 PM
If you find the permanent code, enter it, then press "1", wait a second, then enter the 5-digit code of your choosing. This code can be changed the same way, and it will quit working if you disconnect the battery.
There is a way to decode the thing (and possibly change the permanent code) if you know how. It involves the positioning of five resistors on the circuit board inside the box. It was posted on the old board at www.foxtbirdcougarforums.com , but I couldn't find it on the new one. Might post there & see if anyone remembers it.
Old 10-17-2005, 12:22 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
The original code is located on one of three places, trunk hinge, a plastic card in the glove box or on the keylesss entry module located under the rear package tray in the trunk. Enter the original code, within 5 sec press the 1/2 button, within 5 sec. enter your own 5 digit personal #. Wait 5 sec until the illuminated keypad turns off. Now you can use the original # or your own #. The module does not accept sequential #s (12345) or repetitive #s. (55555)
Old 10-17-2005, 08:10 AM
71 c-10's Avatar
thanks a bunch ya'll! we found the factory code in the trunk and now i'll tell him how to program his own in there.
Old 02-18-2006, 02:23 AM
drlover1983
hey i done wut u said and all it does is add a number it dont get rid of the old .... how will i get rid of the old....... thanks
Old 02-21-2006, 09:16 PM
See the second paragraph of my above post.
biometric rfid keyless entry Jon Hotrodders' Lounge 9 04-02-2005 09:29 PM
GM Keyless Entry Problem jradf Electrical 1 11-20-2004 02:09 PM
88" Lincoln Mark VII Keyless Entry chianesi Electrical 2 08-23-2004 09:40 AM
Door Actuators, Remote Keyless Entry, Alarm -- Good Deal? skizot Electrical 0 03-30-2004 12:59 PM
Keyless Entry 4811 Electrical 3 03-28-2002 05:47 PM
