lincoln locker - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2011, 04:06 AM
lincoln locker
ok guys im new and like most people have a project fund of about $0 so what are the pros and cons of welding up my 12 bolt with 3.07s and 30 inch tires in a longbed truck with a smallblock,
im also a young defiant son of a ****** and im probably gonna do it anyway
but maybe somebody out there can change my mind
so here is the info on the truck
its a 1965 chevy c10 long bed 2wd
cammed 350 with a massive 795cfm edelbrock and a full 2 1/2 inch exhaust through cherry bombs
3.07 open diff
30 inch all terrains
this thing will see the track quite often and it will be going up to the mountains quite often
and its my dd
Old 08-15-2011, 04:39 AM
10 bolt Lincoln Locker
We welded up the spider gears 10 bolt differential on a '69 Tempest for 1/4 oval track enduro racing and it worked good.
Old 08-15-2011, 06:22 AM
Wiki Edits: 27
a close look at the pine trees
with a welded up rear you will probably get a real close look at some pine trees when you come around a corner on a gravel-dirt rough road
Old 08-15-2011, 06:53 AM
With a budget of $0, I see a problem with needed tires. Lincoln Lockers eat tires. A buddy of mine did this to a Firebird he loved and later sold it 'cuz he hated it. Have a backup plan before breaking out the sticks.
Old 08-15-2011, 07:48 AM
Detroit Locker
I had a rare factory Detroit Locker in my '63 Pontiac Catalina. It wore out both rear tires prematurely and when locked, the differential tried to push the car in curves before it unlocked with a loud clank. I did not have power steering and it was a chore to turn the car before the differential unlocked.
When I straightened the car out and the Detroit Locker locked up, I again heard a loud "clank" which shook the car. I got tired of that crap and traded it to George Kevelbaard in Hanford CA for a regular Safe-T-Track. Kenevelbaard is the owner of the late Mickey Thompson's 1963 Pontiac 421 Super Duty Catalina. George used it for a while and got rid of it also.
I had just as well have a Lincoln locker or a spool as a Detroit locker, but only if the car will be driven off road. At least a spool would not be noisy and unpredictable.
Old 08-15-2011, 08:49 AM
Some trucks these days come with factory airlockers I believe. Maybe you can find a setup and graft it into your rig. It might be worth your while to look into that. A guy with a 30s willys coupe and a V6 got killed when his locker hooked unevenly trying to switch lanes in the rain at a rod run. Lockers are great, but man will you pay for it in tires and dents.
I know what you're trying to do; but I think it will cost you more than saving your pennies and buying something stronger and more appropriate. Don't forget if you shatter that thing, since its your DD, fixing it will cost you (down)time and money you probably cant afford.
Worst thing I ever did was build a balls-out street car for my daily. I couldnt drive it certain places, sometimes I had to bum rides to get to work because I couldnt afford the gas, and I spent so much in tires, carb kits and loud pipes tickets....I sold it to go to college and now the daily is a STOCK TPI Trans-AM WS6. It gets in the 20s for MPG on the highway, drinks 87 octane and has A/C and C/C. Im looking at a weekend only car, that'll be a lot more agressive however.
Old 08-15-2011, 01:41 PM
thanks for the replys guys as for tires i can get a good used tire for 20 bucks mounted and i will at all times have two spares rollin around in the bed,
the tire place i go to has been in business forever and they aren't going out anytime soon
i get one wheel wonder action around damn near every corner, so im used to replacing tires
kmatch my cousin picks up scrap trucks and cars all the time so i can probably get an extra diff from him,
i wont make a move unless i have a backup
Old 08-16-2011, 01:37 AM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
While you have the rear end tore apart in that truck, look into getting a shorter set of gears for the rear. You can pick up a set of gears at a salvage yard for cheep and the shims to instal it aren't that expensive either. Normally i wouldn't recommend doing that, but with welded spider gears that rear end isn't going to last that long anyway. Might as well have some fun while your at it, and that small block will really like the shorter gears.
And for my $.02 i would get rid of that carb... its wayyy to big for that motor. Sell it and pick up a 600 or 650, you will be amazed at the difference.
jag irs with locker? jagking Transmission - Rearend 4 12-20-2009 12:37 PM
detroit locker or powertrax locker??? elcaminodragster Transmission - Rearend 7 10-13-2009 08:44 PM
locker kwopper07 Transmission - Rearend 2 11-19-2007 04:05 AM
"lincoln locker" 86K5blzr Transmission - Rearend 3 10-30-2006 09:50 AM
Detroit Locker henny496 Transmission - Rearend 8 11-06-2005 08:34 PM
