Lincoln Rear Disc Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2002, 02:26 PM
Post Lincoln Rear Disc Brakes
How do you get the calibers apart.The Puck seams to screw in or out. Wich way and how far? Thanks, John
Old 12-17-2002, 02:40 PM
aka Duke of URL
Exclamation
It takes special service tools to properly overhaul the rear caliper. It is cheaper to buy exchange units rather than the tools.
If you decide to overhaul regardless, you need the proper FORD shop manual.
Old 12-17-2002, 02:43 PM
aka Duke of URL
Red face
Or...if you are simply replacing pads, there is a special service tool that pushes in and turns the piston simultaneously to properly seat it. If you do not seat it properly, it will break the self-adjusting feature and then you will have to buy the special service tools.
