lincoln transmission harsh - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2008, 08:34 AM
wulf's Avatar
better put thread here instead of engine forum ( woops ) just rebuilt the engine on my daily driver 2000 towncar and the trans at first just felt odd can`t really say what it was but just didn`t feel right ! all shifts have now got very harsh but no DTC`s have been set ! i have been told that its the pressure solonoid playing up but the previous owner says this was renewed 12 months ago ! is it likely to have gone this soon ? fluid still looks and smells new ! the other thing i have been advised is to check the internal wiring loom in the box as being push fit this can sometimes give problems ! opinions anyone ? any help would be great as its hard to get advise this side of the pond
Old 01-08-2008, 06:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would suggest a scan of the vehicle with a quality scanner as a starting point. A scanner that reads the data stream as the vehicle drives.
Old 01-09-2008, 08:07 AM
wulf's Avatar
if only
would love a quality scanner as mine will get into everything bar the trans and the abs ! unfortunately i don`t have access to one and in this country they are few and far between if there is anyone in south east england reading this that has one please lemme know ! even the local limo company doesn`t have one with that sort of capability . untill one is located is there anything else i can do as i am concerned about damaging the box and drivetrain
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
'39 Lincoln Zepher Transmission flathead Transmission - Rearend 3 09-23-2005 07:05 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 09:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
Transmission for 1949 Lincoln WardellW Hotrodders' Lounge 0 03-04-2002 07:22 AM
