Lincoln Versailles Ignition System - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2007, 03:20 PM
Holder350's Avatar
Auto Parts Professional
Hey I recently ran into the weird looking setup on a Lincoln Versailles.
The cap and rotor look like this
Can anyone tell me how these were suppose to work?
My best guess was that it was made to fire each cylinder twice every revolution. Kinda like the new 4cyl designs that use only 2 coils.
I'm not working on the car, just thought that this looked cool or stupid or both .
Old 08-06-2007, 05:56 PM
aka Duke of URL
Those belong to the FORD EEC-I Ignition System which was used on the VERSAILLE very briefly (1979). The points are separated to prevent cross-fire, much like the DURASPARK II cap. This system used a crank sensor, ECM and a DURASPARK II ignition module for spark. EEC-III was a continuation (and improvement) before EEC-IV and TFI became the standard.
Old 08-06-2007, 08:30 PM
Holder350's Avatar
Ok thanks, I wasn't sure about it.
after looking at the rotor and cap closely, I see how that might make the points in the cap and rotor live longer. I guess I just don't understand why you would want to make a simple process more complicated like that.
Old 08-06-2007, 08:47 PM
junkyardjeff's Avatar
I had a 82 F250 with a 351 and the VV carb and it had a similar ignition,it soon got a regular 2 bbl carb and the normal duraspark ignition when it started acting up. I should of learned how to work on it since it did get real good gas mileage for a 3/4 ton truck. Jeff
setting up the Ignition 1970Chevy General Rodding Tech 1 07-20-2007 11:05 PM
Ignition system dutch paul Electrical 10 03-27-2006 09:33 AM
The Ideal Ignition System... sicksixseven Engine 8 01-18-2005 02:39 PM
Ignition system Ratoflic Introduce Yourself 1 12-03-2004 10:20 AM
dead ignition system Mokchirnaff Electrical 8 11-10-2004 07:23 PM
