Lincoln Versailles rear disc brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2007, 08:41 AM
Can anyone direct me to a knowledgable source on LIncoln Versailles rear brackes? I have Versailles disc brakes on the rear of my 28 ford sedan delivery. I bled them last week and got a good firm pedal but after a few miles the right rear got hot and started smoking... couldnt get the calipers pushed back to be able to drive.
the Ebrake lever wasnt moveable so maybe it wasnt adjusted properly?
Anyone with experience or know of someone that has a good working knowledge of this system?
Thanks
Old 10-22-2007, 09:30 AM
Crack the bleeder on the caliper. If it releases, then you have a bad caliper.
Old 10-22-2007, 11:07 AM
aka Duke of URL
This type caliper has a ratcheting piston instead of the design you are more familiar with. When replacing pads, the piston must be turned and pressed into the caliper housing simultaneously. There is a special tool designed for this.
Also, once pads have been replaced, there is an air gap to set to ensure proper pad clearance to the rotor. If the piston has been forced back with a c-clamp, it has been damaged. Trade it on a rebuild.
Old 10-22-2007, 12:12 PM
Versaille disc brakes
Thanks to all those that made the effort to reply to my brake question.. Locally I found a resource that offered a web site that offers very detailed info on the subject.
A recommended read to those needing basic info on the Lincoln Versailles rear end and disc brakes.
http://hetclub.com/disc/brakes.htm
Old 10-22-2007, 12:53 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
That is a great link!!!! Thank you.
Impala rear disc brakes rcc-impala Suspension - Brakes - Steering 1 11-26-2006 03:58 PM
MK VII Lincoln rear disc brake swap Brian S Suspension - Brakes - Steering 6 05-12-2006 12:21 AM
Ford Explorer Rear Disc Brakes Lloyd Topping Jr Transmission - Rearend 4 11-10-2002 02:06 PM
REAR DISC BRAKES BIGBLOCKSTANG Interior 1 10-30-2002 03:41 PM
Rear end and disc brakes for a 66 mustang coup treuno Transmission - Rearend 5 04-23-2002 10:54 AM
