Lincoln Versailles Rear End brake lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2010, 07:17 AM
Fitting Versailles rear end under 66 Fairlane. Need to locate a supplier for the left and right Caliper brake lines. RockAuto's supplier has discontinued them.
Or anyone that buids custom lines, I have the old ones, the rubber is just dry rotted.
Thanks,
Suds
Old 04-28-2010, 07:49 AM
you can get em at any napa, just take in your old ones they are normally the same as the front hoses on a disc brake equiped ford.
Lincoln mark 4 disc brake rear whynot Suspension - Brakes - Steering 11 08-04-2010 05:16 PM
Versailles rear end Suds Hotrodding Basics 2 04-26-2010 09:07 AM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
