Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lincoln Versailles steering and suapension upgrades
Old 02-04-2013, 08:56 AM
timothale timothale is offline
Wiki Edits: 27
the Good and the bad.
All the small block engine improvements, will work. , I 've had a couple , stock and parts cars. Some came with 351's and c 5's, and the last one had a factory sub frame kit installed. and you can't beat the 9 in disc brake rear. The bad, they are heavy, have a longer wheelbase. power steering ram hangs low, speed bumps take out the hoses and fittings, even on a stock height car, Brake- suspension pieces are popular swap parts to the earlier fomoco cars, possible brake upgrades, later larger rotors might fit, and Mustang Cobra multi piston brake calipers are popular swap to the granada, monarch versaille spindle swaps. a lot of the info on the falcoln fairlane mustang forums would apply since major components are shared. they have a lot more heavy sound deadening installed.... interior door handles are weak. don.t close the door with them,
