pressures can go as high as 200 pounds on the high side.what made you decide to get a filter and what does it say in the instructions? You will need to recharge the system and maybe evacuate the system and change the drier receiver if the system is open for a while
It must go in the low pressure line, if you're cutting in. Or, do they include instructions for putting in fittings?
PatM |
Most lines are aluminum and dont seal well, or tend to crumble when you attemp to use a fitting like a compression fitting on them. Flaring it is out.
Using an AC filter is kind of a patch job. If barrier hoses are deteriorating and plugging up the system they need replaced. If there is other debris like dessicant from a rupture bag in a drier, it too needs replaced, and the system flushed. The filter is probably designed for install in the liquid line(small diameter line ) . What kind of issue are you having that makes you want a filter?
Fact is stranger than Fiction |
The only thing the directions say is "install after the condenser in the liquid line". I'm adding the filter because the system has been open for a while during engine work. I flushed the system as best I could, put in a new orifice tube, and have a new accumulator ready to install. Also, this is a van with rear ac (expansion valve & evaporator), and gm recommends adding a filter after doing any work to the system. There is a LOT more to flush with lines running the entire length of the van. My hope is that the filter will catch debris before heading down the lines, especially if/when the compressor fails. future flushing and repair will be much easier and cheaper, or at least that's the plan. Trying to make a sound decision here.
and yes , it definitely seems like a patch job. If it doesnt work, I'll have to track down a line that is very specific to my van-probably in a junk yard. I cut the line today. I got a good clean cut, and the line is in good shape. we'll see... The system was working fine when it was discharged, and I expect it to work again when filled back up. This is a 2001 van. Thanks for the input. Last edited by briansansone; 08-28-2012 at 09:17 PM. |
Your system sounds like it was fine to start with. No contamination. Just moisture possibly. It would be OK with a deep vacuum.
If you had a compressor failure, or hose decomposition , a filter would be a good Idea.Its OK to put one in anyhow. Best of luck.
| filter for air line | pappastang | Garage - Tools | 3 | 10-16-2009 11:40 PM |
| fuel line size to my old filter | ratpackin | Engine | 2 | 05-25-2008 01:07 AM |
| fuel filter in pvc line on sbc | hottrodz | Engine | 5 | 05-23-2008 05:40 PM |
| A filter on your brake boost vacuum line??? | chevy3600 | Suspension - Brakes - Steering | 11 | 02-28-2008 05:16 PM |
| Best AIR LINE FILTER for HVLP guns! | camaro freak | Body - Exterior | 8 | 05-16-2006 12:31 PM |
