line boring costs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2012, 07:47 PM
line boring costs
how much does it cost to line bore a 4 bolt 350 block?
Old 01-10-2012, 08:47 PM
BOBCRMAN@aol.com's Avatar
Depends on your location.. Maintenance line bore (stock caps). $175.00 in my area..
Old 01-10-2012, 10:13 PM
Align hone should be done VS line boring as there are not to many line boring machines that cam line bore all 5 journals in one set up.
I get 185.00 to line hone.
Old 01-11-2012, 07:58 AM
My machine will do 48" no reset.. AMC Denmark.
One advantage of linebore is aftermkt caps are easier to do. You can make the main bore come out anywhere you want it..
Old 01-11-2012, 09:44 AM
Performance engines should be finished with an align hone, We line bore when installing new caps and all the shops I deal with want a line hone finish. When line boring nothing should come out of the block side!!!!!
Old 01-11-2012, 10:48 AM
I agree. I also offer Sunnen line honing. The question was "Line Boring".
In the real world, line boring can save a very expensive or un obtainable block. Thats why there are undersize timing sets available for most applications..
Old 01-11-2012, 11:57 AM
We are set up to blue print bore cam tunnels and from what I have seen GM cam tunnels are all over the place.
Gm line bores the cam tunnel with the bearings in place to correct their screw ups, Try to by a GM OEM block with out cam bearings.
Worst GM cam tunnel I have ever was was out .016
We have a Sunnen line hone set up at each shop!
Line Boring and Timing Chains Carlos9 Engine 3 11-10-2010 12:52 PM
need assistance repairing a boring car with a boring problem ret_marine2003 Engine 10 05-17-2007 08:50 PM
line boring roadrunner89 Engine 14 04-30-2007 02:26 PM
Please Help Me......What is line boring??? AutoChick Engine 10 02-04-2003 10:46 AM
Line Boring G T A Engine 4 05-09-2002 09:12 PM
